L3 Port-Channel To NX7K vPC Domain
zekebashi
Level 4
Level 4
We are considering changing the current vPC configuration of our access-layer switches from L2 to L3. They are currently attached to single-sided vPC domain via L2 Port-channel.
According to the below Cisco document, NX7K doesn't support attaching a end-device to a vPC domain using L3 port-channel. Does NX7K support L3 port-channel?
Page 38of 129
Page 46of 129
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Thanks in advance,
~zK
zekebashi
Level 4
Level 4
I think I found the answer. Yes, L3 over vPC is supported on the NX7K depending on the module model and sw code installed on the vPC peers. Here's the Cisco document:
zekebashi
Level 4
Level 4
