NXOS system software differences 7.x vs 9.x
Hello
We have two Cisco Nexus 9504 connected in a VPC-domain.
Recommended realese is 7.0(3)I4(8b) but we cannot use this release due to incompatible hardware.
we are using these line-cards:
1    52   48x10/25G + 4x40/100G Ethernet Module N9K-X97160YC-EX       ok
2    52   48x10/25G + 4x40/100G Ethernet Module N9K-X97160YC-EX       ok
3    52   48x10/25G + 4x40/100G Ethernet Module N9K-X97160YC-EX       ok
4    52   48x10G + 4x40/100G Ethernet Module    N9K-X9788TC-FX        ok
We are currently using Release 7.0(3)I7(4).
On cisco.com I see a new release called 9.2(2) (and this release seem to work with our hardware/line-cards)
What is the difference between 7.0(3) and 9.2(2)?.....is 7.0 being repaced by 9.x in the future?
Should I stay on 7.0.xxx or go to 9.2.xx? (Cisco TAC are not "allowed" to recommend software to use)
Best regards
Magnus
Mark Elsen
 - As far as differences are concerned, you should read the release notes for 9.x, watch out for new features , changes, etc....
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
dbeattie
v9 is initially an alignment train to allow the convergence of the whole of the N9k and N3k series switches. There is not currently a long-lived v9 release, so it is unlikely that there would be any recommendation to go there except for functionality reasons. I have experienced some issues with 9.2.1, so would suggest that if you want to go for a v9, you use 9.2.2. You might be best served by talking to your Cisco Account SE to get a view of the relevant software road maps.
Hope this helps
Dave
