offloading DHCP static mapping in 12.3(25)?
ocicat002
According to the following:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t11/feature/guide/gtdhcpsm.html
...configuring static addresses via DHCP can be accomplished from a text file found on a tftp server as of IOS 12.3(11)T.
I'm running 12.3(25) on a 2621, but I don't see the form of the "origin" command described at the above link. The documentation above states that the syntax is:
origin { dhcp | aaa | ipcp | file <url> }
...yet, I only see the following options:
Router# conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router (config)# ip dhcp pool MYPOOL
Router (dhcp-config)# origin ?
aaa Subnet is from a AAA server
dhcp Subnet is from another DHCP server
ipcp Subnet is from IPCP subnet negotiation
Router(dhcp-config)#
The documentation states that this functionality was released with 12.3(11)T. Am I correct in assuming that it is not available in 12.3(25)?
ocicat002
I have since gotten this to work using a different IOS image.
Which raises a question: is there any information on what features/functionality can be found in any particular IOS image? Thanks for any insight shared.
Hello ,
software feature navigator tool
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by image option lists the features supported in IOS image
