offset-list failing
I am attempting to apply an inbound offset list to my EIGRP setup. I create the ACL but when I try to apply it to EIGRP AS 12 I get the following error message: % Invalid access list name. What is worse, it seems to add a line to my EIGRP config automatically: offset-list 0 in 3 Serial0/0
See my output below. I'm not sure why this is not working. I am following the instructions in my CCNP Route book but it does not mention these issues.
R4#show ip access-lists
Extended IP access list 111
    10 permit ip host 172.16.1.0 host 255.255.255.0
R4#show run | s router
router eigrp 12
network 10.2.2.0 0.0.0.3
network 10.4.4.0 0.0.0.3
network 192.168.4.0
no auto-summary
eigrp router-id 4.4.4.4
R4#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R4(config)#router eigrp 12
R4(config-router)#offset-list 111 in 3 serial 0/0
R4(config-router)#^Z
R4#
*Mar  1 00:30:05.819: %SYS-5-CONFIG_I: Configured from console by console
network 192.168.4.0
no auto-summary
R4#
I wish to confirm a couple of things:
1) The ACL must permit the network whose metric is being offset and NOT the EIGRP neighbour IP that is giving these metrics. Right?
2) Why the extened ACL is generating a fault and why the router is automatically creating this extra line.
3) When I add an offset-list, do I need to bounce the interface in question? It seems like I do not need to, but I thought updates where only sent with a topology change...
Thanks in advance.
Network Engineer
CCIE SP #69245
Steven, this should be a printing error then, Double check everything u read as u did now, coz there is always a small chance of typo or faulty editing !
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
5 Replies 5
smehrnia
Level 7
Level 7
Hi Steven,
I think u mistakenly misconfigured your access list: host 172.16.1.0 host 255.255.255.0 ? try using an standard access-list with proper ip and wildcard mask.
the automatic command "offset-list 0…" means all routes that are coming in from int serial 0/0. get an offset of 3, and thats because you got ur access-list wrong (invalid).
the interface you add at the end, limits the offset application to the updates (defined in the ACL) that are comming from that particular int. if you remove it, it applies to that ACL comming in all interfaces.
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
I am taking host 172.16.1.0 host 255.255.255.0 directly from my CCNP ROUTE book.
The configuration works with a standard ACL no problems - I just wish to check if I can use extended ACLs (because the book says I can) and why the offset-list 0 in 3 Serial0/0 line is added automatically.
Network Engineer
CCIE SP #69245
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
John Blakley
Steven,
Offset-lists support standard acls. Try changing your acl to something less than 100 and reapply.
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks, this helped
