One direction Bandwidth Issue
sajidabbas
We are having an issue where bandwidth obtained in one direction is quite low as compared to the other direction.
We have done iperf/jperf and also SMB testing in both direction which seems to be giving the same consistent results.
We have the following topology
Station A <-> 6800 <-> 4900M <-> Station B
Station A to B = 50% speed
Station B to A = Full speed
I have seen some other posts similar to this but without any solution.
Anybody can shed light or assist on this.
Sajid
7 Replies 7
Seb Rupik
Hi there,
Do you have QoS implemented in this topology?
If so, it could be that traffic from station B is being marked on ingress into the network and receiving preferable policing along the path to station A.
Station A's traffic on ingress is being placed in the default queue and suffering as a result.
cheers,
Seb.
We do have QoS implemented but have taken it off to do the testing.
I have done some wiresharking and dont see any marking in the packets going through the network.
How to verify on the switch if marking is being done.
what is Station A and what is Station B (e.g. are these 'regular' Windows machines) ? We need to see the output of 'show interfaces x' where 'x' are the interfaces of respectively the 6800 and the 4900 switches the stations are connected to...
Station A and B are win10 machines.
show interface outputs as shown below
Station A
GigabitEthernet105/1/0/26 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 689c.e2e8.7a9a (bia 689c.e2e8.7a9a)
MTU 9216 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is unsupported
Clock mode is auto
Last input 00:00:21, output never, output hang never
Last clearing of "show interface" counters 1y47w
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 35962
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2957000 bits/sec, 269 packets/sec
5 minute output rate 378000 bits/sec, 97 packets/sec
387476361 packets input, 289876840624 bytes, 0 no buffer
Received 1730602 broadcasts (1589183 multicasts)
0 input errors, 0 CRC, 0 frame, 251658240 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
790061723 packets output, 754747609160 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Station B
GigabitEthernet3/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0026.991f.dfff (bia 0026.991f.dfff)
Description: To-TVCRTR1 Gi3/12
Internet address is 172.25.1.129/30
MTU 9198 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseT
input flow-control is on, output flow-control is on
Last input 00:04:32, output never, output hang never
Last clearing of "show interface" counters 21:13:49
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 1000 bits/sec, 1 packets/sec
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
3111757 packets input, 2947831277 bytes, 0 no buffer
Received 1299 broadcasts (0 IP multicasts)
2407785 packets output, 3066572668 bytes, 0 underruns
Hi there,
The overrun value on the Station A interface would indicate traffic loss A -> B :
251658240 overrun
...is station A connected to a FEX? What software version are you running on the 6800?
cheers,
Seb.
Hello Sajid,
are you using Instant access with FEX like dependent modules / satellite switches?
In first implementation of instant access unicast traffic needs to go up to master C6800 to be routed.
In other words Instant access with C6800 and its satellite devices is only suited for access devices not to host servers that may need better performance.
Hope to help
Giuseppe
the flow control settings on both interfaces differ, not sure if that makes a difference, you might want to make sure the settings match (interface command 'flowcontrol receive off/on')...
Station A
Station B
