one way Input Traffic on Cisco switch Trunk, Nothing connected on it
ahmad82pkn
Level 3
Level 3
Hi, i have a cisco switch, nothing connected to it except one trunk cable, there is constant 5 Mbps traffic in to this switch, but no output.
can any one help, how can i find this traffic, what debug i can enable which can help out? i tried debug ip options and debug packet, but no luck
i dont have a sniffer at this time :S
sh int g0/2
GigabitEthernet0/2 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000b.fdf1.181a (bia 000b.fdf1.181a)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseTX
  input flow-control is off, output flow-control is off
  1000BaseT module (WS-G5483) in GBIC slot.
  Last input 00:00:00, output 00:00:10, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5435000 bits/sec, 4744 packets/sec
     969725338 packets input, 2846584134 bytes, 0 no buffer
     Received 10777758 broadcasts (0 multicasts)
     0 watchdog, 8337974 multicast, 0 pause input
     18635 packets output, 2995944 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Amit Singh
Did you try clearing the counters to check if it is still growing at the same rate.
Looks like a lot of  broadcast traffic on this trunk port. This could be a malicious PC or a misbehaving NIC. Please set up a SPAN sesion on the port and use wireshark to capture the MAC or possible IP address of the soruce of the traffic.
For creating SPAN
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#topic5
Download WireShark :
HTH,Please rate if it does.
-amit singh
