Open port
digbym650
 I wish to use port 514 between two pc's on the LAN. I was wondering if it needs to be opened to use it. Port 514 is not listed by;
show ip nbar port-map
Or is this only for outside ports.
digbym650
Problem solved,
show ip port-map
displays SHELL tcp 514
 to activate communications;
ip nat inside source static tcp 10.0.0.102 514 10.0.0.103 514 extendable
