OSPF and BFD
leandroklazen
If I enable BFD for an OSPF instance will it have any effect on neighbor relationships, will they be dropped or reset seeing that the BFD has not been configured on the other end yet?
Leandro
Mark Malone
Hi No it will  not drop the neighbour just from configuring one side it actually wont do anything until you configure both sides and the BFD forms itself
Mark Malone
Hello
As Mark stated the neighour adjacency will not be affected when you enable BFD, in fact it wont be affected even when you apply it on boths ends of the adjacency
res
Paul
Kind Regards
Paul
