OSPF and NAT Problems
martinezaw
I am doing a lab with two 2600 routers with OSPF and NAT. For some reason, the "remote" router for some reason isn't seeing my NAT's block of IP addresses. Can anyone look at my config below and tell what could be wrong?
hostname ACME
ip ssh version 1
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0
ip address 200.0.0.6 255.255.255.252
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet1/1
no ip address
duplex auto
speed auto
shutdown
router ospf 1
log-adjacency-changes
network 200.0.0.4 0.0.0.3 area 0
network 64.64.64.0 0.0.0.255 area 0
ip nat pool acme_access 64.64.64.1 64.64.64.254 netmask 255.255.255.0
ip nat inside source list 1 pool acme_access
ip classless
access-list 1 permit 10.0.0.0 0.0.0.255
line con 0
line vty 0 4
login
end
BTW... OSPF works with just using the private addresses, but as soon as I try to introduce NAT...>poof<... no connectivity.
2 Accepted Solutions
Jon Marshall
The network command under OSPF configuration does not tell OSPF to advertise that network. It tells OSPF to run OSPF on any interface that falls under the 64.64.64.0/24 ip range.
You will need an interface from that range. You can use a loopback address for this
int loopback 10
ip address 64.64.64.1 255.255.255.0
ip ospf network point-to-point
Note that you need the "ip ospf network point-to-point" line otherwise OSPF will advertise a host route for the loopback.
Jon
Glad you got it working.
The network statement does the same thing under EIGRP/RIP as it does under OSPF. So yes you would need to create an interface but you don't need an equivalent to the ""ip ospf network point-to-point" as it is a specific thing to OSPF that loopbacks get advertised as host routes by default.
Jon
7 Replies 7
Jon Marshall
int loopback 10
Jon
martinezaw
I have actually updated the config:
hostname ACME
ip ssh version 1
ip nat inside
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0
ip nat outside
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
router ospf 1
ip classless
line con 0
line vty 0 4
login
end
Jon... thanks for responding! I will try out your config change when I get access on the routers again... which hopefull will be tonight
Not sure what you mean here ?
I realized that on the first config I posted, I did not have ip nat inside and ip nat outside on the appropriate interfaces, so I added that to the second config I posted.... just in case somebody tried to point that out to me.
I can't wait to try out your solution though. Thanks, again!
Oh okay, no problem. Let me know how you get on.
Jon
It worked!!
Thanks A LOT Jon!
It even worked with me running VLANs. Cool.
One more thing though... what if the protocol I used was EIGRP or RIP? Would I still have to have a loopback address and if so, is there an equivalent EIGRP / RIP command for "ip ospf network point-to-point"...as in a command that does the same thing for those protocols?
Jon
