OSPF area range command
maxim.alyakin
Hi all!
Im reading the book "OSPF Network Design Solutions"
and in chapter with ABR\ASBR routers configurations there are some examples of area range command:
im confused with area mismatch in network command (area 0), and area range command (area 1) for same networks (130.10.2.0/24 and 130.10.3.0/24). isthis a mistake or Im something don't understand?
Alessio Andreoli
Level 11
Level 11
Hi Maxim,
there is not only one answer. Depending from the design and from the interface configuration you can see more options..
one more for example could be that the author used 130.10.1.0/24 in area 1 and this would be a summarisation of few smaller subnets (/27 for example) present in area 1. Hence the mistake could be in the area range command on the mask that had to be:
area 1 range 130.10.1.0 255.255.255.0
Alain's one could be one option more but generally you should understand the design to understand whether that is a misake or not. We have not enough data to tell you where precisely the error lies (if any in place)
Take Care
Alessio
cadet alain
yes indeed the area range command should have the 0 instead of 1 as the components subnets are in area 0.
Regards.
Alain
Alessio Andreoli
Level 11
Level 11
Hi Maxim,
Take Care
Alessio
Thanks all
There is no topology for this example, so I think its not best address allocation if there is no mistake
