OSPF default route into EIGRP
Not applicable
Hi, I have default route learned from OSPF and i want to redistribute it into EIGRP in a 4948 switch but it doesn't work:
SW49:48:
router eigrp 100
 network 192.168.1.0 0.0.0.3
 redistribute static
 redistribute ospf 2 match internal external 1 external 2
router ospf 2
 router-id 10.10.10.1
 log-adjacency-changes
 redistribute connected subnets
 redistribute static subnets
 network 10.10.10.0 0.0.0.3 area 2
Switch#sh ip ro ospf
O*E2 0.0.0.0/0 [110/1] via 10.10.10.2, 17:08:49, Vlan7
R2:
router eigrp 100
 redistribute static
R2#sh ip ro
Gateway of last resort is not set
      1.0.0.0/32 is subnetted, 1 subnets
C        1.1.1.1 is directly connected, Loopback1
      192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/30 is directly connected, FastEthernet1
L        192.168.1.2/32 is directly connected, FastEthernet1
Could somebody help me?
Try adding this command under router eigrp
default-metric 10000 10 255 1 1500
Hello
This metric is required as eigrp doesnt understand the ospf metric it is redistributing
You can also apply the metric to the redistribution :command:
router eigrp xxxx
redistribute ospf  metric 10000 100 255 1 150 match internal external 1 external 2
res
Paul
Kind Regards
Paul
