Ospf default route !
illusion_rox
I would like to know that suppose i have an ABR that is connected to area 1 and 0. Area 1 is normal, i want to advertise default route from this ABR to only area 1 and not area 0, can you kindly tell me the way by which i can achieve this ?
i dont think default information originate gives me any such option, so what you guys think ?
Nagendra Kumar Nainar
HI rox,
If you dont have any limitation, you can configure Area 1 as Stub or NSSA and a default route will be advertised by ABR. If you configure "default-information originate", a type 5 LSA will be generated and so you cannot filter it to a particular area.
HTH,
Nagendra
ok taking it as a final word :), can u tell me that we can make virtual link in ospf via two methods,
1) virtual link command
2) gre tunnel
is there also a third way of doing it ??
Rephrasing,
When an ABR is not directly connected to backbone area (Area 0), we can do any of the following :
1. Configure a virtual link using "area virtual-link "
2. If the area via which the virtual-link is to be built is STUB, we use GRE tunnel between ABR and configure the tunnel in AREA 0.
HTH,
Nagendra
Thanks Nagendra, but what about the 3rd method of building this virtual link ?
any idea ?
