OSPF Forwarding Address
rakeshvelagala
Level 3
Level 3
Dear All,
Please advise on the below.
In OSPF, route will not be installed in the routing table if the forwarding address is not learnt via OSPF. So if I have created a static route for the forwarding address on the router, the route will be missing though it will be in database.
I understand it is RFC specification. But what is the reason for designing that way?
Rolf Fischer
Level 9
Level 9
the purpose of a non-zero forwarding-address is to avoid unnecessary hops if a third-party next-hop exists for an external route.
Several checks to prevent routing-loops and ensure reachability must be passed before an ASBR sets the forwarding-address to an non-zero IP-address:
The third-party next-hop has to be directly connected on an ASBR's interface, which is
  • (non-passive) OSPF enabled
  • no OSPF point-to-point or point-to-multipoint interface
When this conditions are met, the corresponding network must be learned as an OSPF internal route. Before another router installs the external route in its routing-table, it just checks if this is the case; otherwise something went obviously wrong and it doesn't install the route.
Cisco Document 13682: Common Routing Problem with OSPF Forwarding Address
Rolf
P.S.: I focussed on standard area types, the usage of the FA in NSSAs is slightly different.
Rolf Fischer
Level 9
Level 9
Rolf
