01-28-2013 11:15 AM - edited 03-07-2019 11:21 AM
I have a OSPF routing issue
Say we have 3 routers
R1 and R2 are connected through a physical interface, useing the config:
interface GigabitEthernet1/0/28
switchport trunk allowed vlan 1,2,3
switchport mode trunk
router ospf 1
area 0.0.0.0 authentication message-digest
network 10.0.0.0 0.0.0.15 area 0.0.0.0
network 10.1.0.0 0.0.0.31 area 0.0.0.0
network 10.2.0.0 0.0.255.255 area 0.0.0.0
They are transfering OSPF routes between each other.
So R3 is connected to R1 through a network drop and into an interface also using the config below on both sides and same ospf router 1 above.
However on R3 I am not getting any OSPF routes....any thoughts?
01-28-2013 12:07 PM
can u please provide more details
the interface configs on the routers can be useful
01-28-2013 01:08 PM
you may have an authentication string mismatch. Run "debug ip ospf events" and you should see if that is the case. If there is a mismatch, no routes will show up in the table.
HTH,
Steve
