OSPF Issue
Amin Shaikh
I have service provider between my two sites and ospf doesnt seems to work..
Service-provider confirms that OSPF is enabled on the DATA-link provided between two sites...
Is there a way to check if the ospf is getting blocked at the service provider...
17 Replies 17
How can I block IP range 192.168.5.0/24 and allow 192.168.1.0/24 on frame-relay interface
Amin:
Please post the full router configurations for the routers on both ends. That is what is needed to understand what you need and help you.
Victor
Thanks to all.
It was DATA Service provider issue, without any changes got it working...
