OSPF LSA start throttle
Dears
Would like your assistance please in confirming my understadning regarding OSPF LSA generation delay
If OSPF is configured with default values, then first router/network LSA will be delayed by 500 ms (actually not shown in commands but mentioned in documents !), and subsequent same LSAs will be delayed by 5 seconds as shown below output
As with SPF computations, we can configure LSA start throttling with command "timers throttle lsa" and this will override previous behavior
Now If I am correct, why in command reference it mentions that default values for "timers throttle lsa" is as below when this command is not enabled by default
start-interval : 0 milliseconds
hold-interval:5000 milliseconds
max-interval: 5000 milliseconds
R2(config-router)#timers throttle lsa all ?
  <0-600000>  Delay to generate first occurrence of LSA in milliseconds
R2(config-router)#timers throttle lsa all 0 ?
  <1-600000>  Minimum delay between originating the same LSA in milliseconds
R2(config-router)#timers throttle lsa all 0 50 ?
  <1-600000>  Maximum delay between originating the same LSA in milliseconds
R2(config-router)#timers throttle lsa all 0 50 60
R2#sh ip ospf  | i sec
Initial SPF schedule delay 5000 msecs
Minimum hold time between two consecutive SPFs 10000 msecs
Maximum wait time between two consecutive SPFs 10000 msecs
Minimum LSA interval 5 secs  <<-------
Minimum LSA arrival 1000 msecs
LSA group pacing timer 240 secs
Interface flood pacing timer 33 msecs
Retransmission pacing timer 66 msecs
Sherif Ismail
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What you're reading, about the 1/2 second delay, might pertain to IOS before the OSPF LSA throttle option was added as a feature.
Hi Joseph
Yes thinks so but wonder why even in latest IOS command reference 15.3S it is mentioning default values when feature is not configured by default
Could you provide a link to what you're reading?
Hi Joseph
Please check below URL
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_ospf/configuration/15-s/iro-lsa-throt.html
Appreciate your assistance
Sherif Ismail
Ok, unless I'm missing it, I didn't see a reference to holding the first LSA for 500 ms.  By default, the first LSA is sent immediately and next LSA is held for 5 seconds.
Is the issue the shown "Minimum LSA interval 5 secs"?  If so, consider the word "interval" as in time between LSAs, which would be 5 secs, by default.
Hi Joseph
mmm could be .. please check below ospf o/p before and after configuring LSA throttling
7606-1#sh ip ospf 1 | i sec
Initial SPF schedule delay 50 msecs
Minimum hold time between two consecutive SPFs 1000 msecs
Maximum wait time between two consecutive SPFs 5000 msecs
    restart-interval limit: 120 sec
7606-1#
7606-1#conf t
7606-1(config)#router ospf 1
7606-1(config-router)#timers throttle lsa 0 1000 5000
Initial LSA throttle delay 0 msecs
Minimum hold time for LSA throttle 1000 msecs
Maximum wait time for LSA throttle 5000 msecs
7606-1#
Many Thanks
Sherif Ismail
Disclaimer
Posting
Hmm, that's interesting.  It appears it accepted the timers throttle command's values.  But before you used that command, I now wonder if it is default to earlier Cisco defaults.  What IOS is this?
Hi Joseph
I tried it on 124-25d at GNS3 and on a 7600 using IOS 15.3S1 and both were giving same result
Also you may find below post intresrting .. Now I am finding for an answer for both topics
https://supportforums.cisco.com/message/3917690
Sherif Ismail
