OSPF neighbors in VRF
pgyogeshkumar
What is the command to check all ospf nieghbors in a VRF in a Cisco 6509 switch
Reza Sharifi
Try
show ip ospf vrf xxxx  neighbor
I believe IOS supports the 'vrf' keyword in show-commands only for OSPFv3 with AFI-support.
But you can use the process ID instead, which also is easier to type:
(config-rtr)# router ospf 5 vrf VRF-5
# show ip ospf 5 neighbor
You can also find out the PID with
# show ip protocol vrf <VRF-Name>
Rolf
Thanks rolf this helped
how to check pim neighbor in a vrf with same cisco 6509 ?
Should be show ip pim [ vrf <vrf-name> ] neighbor
(12.2(18)SXE: Support for this command was introduced on the Supervisor Engine 720.)
Rolf
