OSPF Point-to-Point Question
josh94950
I am trying to understand the following configuration, any help would be highly appreciated.
From the destribution block we have uplinks to core , where we used point-to-point ( not sure why ) also priority and cost was configured ....will it work ?
DIST1A#sh run int t5/5
Building configuration...
Current configuration : 194 bytes
interface TenGigabitEthernet5/5
description Connection to CORE1B T1/5
ip address 10.8.8.61 255.255.255.252
ip ospf network point-to-point
ip ospf priority 255
arp timeout 1200
end
DIST1A#sh run int t5/4
interface TenGigabitEthernet5/4
description Connection to CORE1A T1/5
ip address 10.8.8.57 255.255.255.252
arp timeout 1200
end
DIST1B#sh run int t5/5
Current configuration : 190 bytes
description Connection to CORE1B T2/5
ip address 10.8.8.69 255.255.255.252
ip ospf cost 255
arp timeout 1200
end
DIST1B#sh run int t5/4
description Connection to CORE1A T2/5
ip address 10.8.8.65 255.255.255.252
ip ospf cost 255
arp timeout 1200
end
josh
Hello Josh,
having set the OSPF network type to point-to-point no OSPF DR election occurs on segment and so the ospf priority  is not effective on this link.
the use of OSPF  network point-to-point on LAN interfaces is used for fiber based point-to-point links where you know that there are only two devices and you want to save some resources by avoiding to elect one router OSPF DR and one OSPF BDR.
I think that the OSPF priority has been set as a safety measure should someone remove on both sides the ip ospf network point-to-point command it would be clear who would be elected OSPF DR on segment.
Hope to help
Giuseppe
Jon Marshall
Josh
Not sure exactly what you query is. Basically from each distribution switch you have 2 L3 P2P uplinks to the core switches. So yoy have a routed L3 distro/core setup which is quite common. Each distro switch will see 2 equal cost paths to destinations reached via the core.
Is there something specific in the config you think might not work ?
Jon
Jon,
Thanks and you are right on distribution blocks to core, however I am confusing with the priority and cost on point-to-point interface  .... is that a reason to configure in this way or ..
from Dist 1A   ------------------>    Core 1A            Priority is setup to 255  , default cost
       Dist 1A   ------------------->   Core 1B            Priority is setup to 255 ,  dafault cost
From Dist B -------------------->   Core 1A             Cost is 255 , default  priority
         Dist B -------------------->   Core 1B            Cost is 255 , default priority
Hello Josh,
Hope to help
Giuseppe
