OSPF Redistribution - default route missing
udo.konstantin
Level 5
Level 5
I found the following scenarium:
Our customer has on ots core switches two ospf processes running.
One ospf process injects a default route. This default route should also redistributed into the other process. And therefore inject into te second backbone area.
The command "sh ip ospf process <1> database shows the o.o.o.o route
After redistribution :
Redistribute ospf 1 subnets metric-type 1
The default isn't in the second ospf database?! All other routes are redistributed?!
Any idea?
Udo
Peter Paluch
Hi Udo,
You can not redistribute a default route into OSPF, at least in Cisco's OSPF implementation. OSPF on Cisco devices specifically avoids redistributing the default route into OSPF. The only way to inject a default route into OSPF is to use the default-information originate command in the appropriate OSPF process.
Best regards,
Peter
Thank you Peter...
That is what I also thought...but please can you tell me where I can read this ? RFC ?!
Udo
here is a cisco link on the default info ori and default route
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00801ec9f0.shtml
Hello Udo,
This behavior is not specified in any RFC to my best knowledge. It is an implementation choice made by Cisco. However, the following document
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094374.shtml#route0.0
specifically states:
The default routes created using the ip route 0.0.0.0 0.0.0.0 command are not propagated by OSPF and IS-IS. Additionally, this default cannot be redistributed into OSPF or IS-IS using the redistribute command. Use the default-information originate command to generate a default route into an IS-IS or OSPF routing domain. For more detailed information on behavior of default routes with OSPF, refer to How Does OSPF Generate Default Routes?
Best regards,
Peter
