OSPF Static route redistribution and route map question
Craddockc
Level 3
Level 3
Community,
For some reason I cant seem to get my route map to work. I am trying to redistribute static routes into the OSPF 1 process so they can be advertised using the following:
router ospf 1
redistribute static route-map Static-Routes
route-map Static-Routes permit 10
match ip address Static-Routes
ip access-list Static-Routes
10 permit ip any any
What I want to accomplish is this. I want to redistribute all static routes except for 10.10.10.1 but all other static routes need to be advertised via OSPF. This is on a nexus 9K by the way so I think the "subnets" option is on by default. No classful redistribution happening. I tried setting up my "Static-Routes" ACL like this but it didnt work:
5 deny ip 10.10.10.1 0.0.0.0 any
Im thinking I need a deny clause in my route map but im not sure how to set this up. Can you guys/gals help? Thanks.
Julio Garcia
I would use a standard ACL instead of extended, or even an IP Prefix list.
5 deny 10.10.10.1 0.0.0.0
10 permit any
Then create a second clause to deny the rest of routes to be redistributed (although this clause is redundant since by default there is an implicit deny in a route-map applied to redistribution according to documentation)
route-map Static-Routes deny 20
Another way of doing it is denying first and permitting afterwards:
ip access-list 1 permit 10.10.10.1 0.0.0.0
route-map Static-Routes deny 10
   match ip address 1
route-map Static-Routes permit 20
Julio
Julio Garcia
10 permit any
   match ip address 1
Julio
