OSPF Static Route Redistribution Tweak
Sighclops
I have a router running OSPF and have it set to redistribute connected and static routes. I would like to add a static route to a router but not have this particular route redistribute, while all others still do. How can i accomplish this on my 7609?
Rolf Fischer
Level 9
Level 9
you can use a route-map to control which routes are redistributed. There are several options to tell the route-map which routes to filter out, one powerful option would be a prefix-list.
Example:
Redistribute all static routes except for 192.168.1.0/24
! deny 192.168.1.0/24 and permit everything else
ip prefix-list FILTER-STATIC seq 10 deny 192.168.1.0/24
ip prefix-list FILTER-STATIC seq 20 permit 0.0.0.0/0 le 32
route-map STATIC-2-OSPF permit 10
 match ip address prefix-list FILTER-STATIC
router ospf 1
 redistribute static metric-type 1 subnets route-map STATIC-2-OSPF
Rolf
Rolf Fischer
Level 9
Level 9
Example:
router ospf 1
Rolf
Thanks Rolf... exactly what I was looking for!
You're welcome! Thanks for using the rating system.
