OSPF Strange but interesting !!
illusion_rox
hi guys, pls tell me about this !
if i have 2 routers connected via ethernet link, R1 ip is 10.1.12.1/8 and R2 ip is 10.1.12.2/24, the adjancy doesnt come up,
If the link is p2p the adjancy does come up !!!, why is that so ?? i have gotten the feedback that in p2p subnet mask doesnt match ! but i havent read it anywhere or if i have i dont remember it clearly, can you pls tell me why does it happen, i will be grateful if you could refer me any cisco doc or book or RFC that addresses this issue !!
Harold Ritter
Ovais,
This behavior is compliant with RFC2328 section 10.5:
"However, there is one exception to the above rule: on point-to-point networks and on virtual links, the Network Mask in the received Hello Packet should be ignored."
http://www.ietf.org/rfc/rfc2328.txt?number=2328
