Output from debug ip packet
mahesh18
Level 6
Level 6
hi all,
here is output from ACL  110
2650XM#debug ip packet 110 de
2650XM#debug ip packet 110 detail
IP packet debugging is on (detailed) for access list 110
2650XM#ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/51/56 ms
2650XM#
Oct 13 14:00:16.220 MST: IP: tableid=0, s=96.51.x.x (local), d=4.2.2.2 (FastEthernet0/0), routed via FIB
Oct 13 14:00:16.220 MST: IP: s=96.51.x.x (local), d=4.2.2.2 (FastEthernet0/0), len 100, sending
Oct 13 14:00:16.224 MST:     ICMP type=8, code=0
Oct 13 14:00:16.272 MST: IP: tableid=0, s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), routed via FIB
Oct 13 14:00:16.272 MST: IP: s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), len 100, sending
Oct 13 14:00:16.272 MST:     ICMP type=8, code=0
Oct 13 14:00:16.324 MST: IP: tableid=0, s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), routed via FIB
2650XM#
Oct 13 14:00:16.324 MST: IP: s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), len 100, sending
Oct 13 14:00:16.324 MST:     ICMP type=8, code=0
Oct 13 14:00:16.376 MST: IP: tableid=0, s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), routed via FIB
Oct 13 14:00:16.376 MST: IP: s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), len 100, sending
Oct 13 14:00:16.376 MST:     ICMP type=8, code=0
Oct 13 14:00:16.428 MST: IP: tableid=0, s=96.51.x.x(local), d=4.2.2.2 (FastEthernet0/0), routed via FIB
Oct 13 14:00:16.428 MST: IP: s=96.51.x.x (local), d=4.2.2.2 (FastEthernet0/0), len 100, sending
Oct 13 14:00:16.428 MST:     ICMP type=8, code=0
config of acl 110
access-list 110 permit icmp host 96.51.x.x.176 host 4.2.2.2
it is applied to interface
Building configuration...
Current configuration : 271 bytes
interface FastEthernet0/0
description WAN Connection to ISP modem
ip address dhcp
ip access-group 110 out
My question is that when we ping some ip we send echo  and get back echo reply from that IP  but here as per debug we see all the pings from source ip 96..x.x.x.  to destination which is 4.2.2.2.
if someone can explain me the out put of above debug please?
thanks
mahesh
Mahesh
Yes, you would need to add another line to your acl 110 ie.
access-list 110 permit icmp host 4.2.2.2 host 96.51.x.x
Jon
Jon Marshall
mahesh18 wrote:
hi all,
2650XM#ping 4.2.2.2
2650XM#
2650XM#
config of acl 110
access-list 110 permit icmp host 96.51.128.176 host 4.2.2.2
ip address dhcp
thanks
mahesh
Mahesh
Not sure what you are asking here.
An outbound access-list applied to a router interface does not stop the router itself sending out ICMP packets. It stops clients behind the router but not the router itself. That is why even with the acl applied you can still ping from the router.
As for the debug, well you only see thos packets in the debug because you are using acl 110 in the debug and only those packets are being matched.
Jon
Hi Jon,
thanks for reply
i was asking this thay when we ping  the remote ip 4.2.2.2  and use debug command why we do not see the reply coming from destination
4.2.2.2  echo reply?
is this because we have debug config  only from source to destination?
thanks
mahesh
Mahesh
Jon
Many thanks  again john
It worked now
Mahesh
