outside source static NAT
andrew.greaves
I'm having an issue with static NAT over an ISDN interface. Router won't dial.
the outside source addresses are natted to IP addresses from the local ethernet0 subnet
config is:
username xxxxxxx password 7 082814680E10304E46
isdn switch-type basic-net3
interface FastEthernet0
ip address 192.168.243.49 255.255.255.240
ip nat inside
no ip route-cache
speed auto
interface BRI0
no ip address
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool-member 1
dialer pool-member 2
no snmp trap link-status
no cdp enable
ppp authentication chap
interface Dialer1
description ****ISDN****
ip address 194.15.247.34 255.255.255.252
ip nat outside
encapsulation ppp
dialer pool 2
dialer remote-name xxxx
dialer idle-timeout 360
dialer string 00123123123123
dialer-group 1
no cdp enable
ppp chap hostname xxxxx
ppp chap password 7 030D082D010614345
ip nat outside source static 172.27.34.53 192.168.243.53
ip nat outside source static 172.27.34.52 192.168.243.52
ip route 172.27.34.52 255.255.255.255 Dialer1
ip route 172.27.34.53 255.255.255.255 Dialer1
dialer-list 1 protocol ip permit
i'm sure its a problem with the NAT
SHOW IP NAT TRANS YIELDS:
Pro Inside global Inside local Outside local Outside global
--- --- --- 192.168.243.52 172.27.34.52
--- --- --- 192.168.243.53 172.27.34.53
which is correct.
the isdn does work as i can ping accross the dialer to the other end. The problem is when a user on the inside targets the NAT address, the router won't dial.
any ideas
regards
Andy
Giuseppe Larosa
Hello Andy,
what if you add also the mirrored NAT static entries for inside to outside?
with your current configuration NAT works well if the session is started from outside to inside.
you may consider to add the option extendable
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1011984
Hope to help
Giuseppe
