Packet trace and spanning
SHAIHAN JAFFREY
Level 2
Level 2
I have 2 core switches hsrp running between. Three access layer switches are connected to these core switches. Vlan 220 configured on the core switches with vtp running.
How do I accomplish the below mentioned points on my network to troubleshoot interVlan leakage.
- Fully detailed physical layer packet trace of Vlan220, to check for any device in between that could be
leaking the pkts or causing a loop
- Sniffer traces - spanning the ports interconnecting Vlan220
Antonio Knox
Level 11
Level 11
I don't understand your question.  You are attempting to avoid inter-vlan leakage, but from your description there is only one vlan.  Inter-vlan traffic is considered traffic between two or more vlans.
Yes it is between two vlans. The other vlan is a voice vlan 221 on the same switch.
