packet tracer 6 does not support "ip ospf network-type point-to-point"
jpcapobianco
hi. i'm trying to use this command in packet tracer 6 with OSPF
" ip ospf network-type point-to-point"
but i've noticed that does not work.
anyone knows if it is supported or not ?
InayathUlla Sharieff
Not sure of 6. I have 5.3 version and this is working fine there.
Router(config)#int s0/3/0
Router(config-if)#ip ospf network point-to-point
Router(config-if)#exit
Router(config)#
Inayath
i mean if a try to use it with a LOOPBACK interface, it does not work.
can i create a LOOPBACK interface, and then advertise it, without / 32 in packet ?
that's what i want to do....
