Packet Tracer Help ACL
logankahn138226
I had everything setup but I think I messed up up the ACL, It wont ping anymore. Im suppossed to Complete routing using OSPF and all PC's should be able to ping each other but not the server. The server should be reachable to open the web page. My packets keep getting stopped at the first router it hits and I cant figure it out.
Martin L
I removed ACLs from interfaces on router but PCs failed pinging. Following are errors I found with ACL removed:
There are no OSPF routes on routers.
R3 should be router on a stick
Vlans are missing on switches
PCs do not have gateways setup
Are you sure you attached correct PT file?
Regards, ML
**Please Rate All Helpful Responses **
I am clearly not very good at this software
Here are some options:
1. Follow CCNA book chapter on IPv6
2. Search online for some CCNA Labs, videos on subject
3. Visit CLN, Cisco Learning Network, https://learningnetwork.cisco.com/s/discussions
Regards, ML
