Packet Tracer Not showing Labels in logical view
panchociti2
Hello Community! I have a problem, when I click on show logical view it just shows "F".
luis_cordova
Hi @panchociti2
Try this:
1-Switch to simulation mode
2-Run a ping to any device
3-Click play
4-Now the names of the sinters should be displayed
https://community.cisco.com/t5/discusiones-routing-y-switching/interfaces-packet-tracer/m-p/3936075#M6530
Jaderson Pessoa
hello,
try to use this tutorial: https://networkengineering.stackexchange.com/questions/54394/how-can-the-cisco-packet-tracer-show-the-ports-name
Jaderson Pessoa
*** Rate All Helpful Responses ***
luis_cordova
Hi @panchociti2
Try this:
3-Click play
XXXCEO
Open the packet tracer ------ from the option tab in the menu bar, select preferences ---------- under interface option, tick the box for “show device name label”
This worked for me. Cisco Packet Tracer 8.1.1
D3F4ULT
On top of packet tracer there is bar with options like File, Edit, ... click on Options -> Preferences... In first tab called Interface, left side of a window, there is option called "Always Show Port Labels in Logical Workspace" make sure box next to it is ticket out.
