packet tracer UI is too large to work
fanofdark
Hello Everyone,
I recently installed packet tracer 8.0 in a 14 inch windows 10 laptop,
The icons, sub-windows everything are too big and non minimizable , its too uncomfortable to work and even to close the opened sub-windows inside although I haven't changed any setting.
currently, I am using this in a ubuntu VM but I am more comfortable to work in host system.
I tried re-installing, but still the problem is active.
I am not getting what was wrong!, Please help me.
Thanking you in advance.
Look , how big they are!!Look , how big they are!!
Had the exact same issue, tried the following steps in Windows 10:
  • Right-click on Packet Tracer Icon (on Desktop/startup menu) and select "Properties".
  • In the "Compatibility" section, select "Change high DPI settings".
  • Mark on "Override high DPI scaling behaviour."
  • Under the "Scaling performed by:" drop-down list, select "System(Enhanced)"
  • Apply this change and try opening the packet-tracer again.
This fixed the issue for me
7 Replies 7
Martin L
You are not only one; same or similar issues have been reported; it seems that only Windows OS has no issues;
MAC OS and Ubuntu have some issues when running PT.  Not sure how to help you besides reporting issues to PT people. You can use link from PT Help menu > Report an issue. or this link
https://app.smartsheet.com/b/form/e8051c092e07401aa7d50ec2424a6e1c
Regards, ML
**Please Rate All Helpful Responses **
How can i fix this UI issue,I am using windows 10 64 bits. so annoying this thing
It works.
Thank you for sharing the solution @patrickolvera
I too have the same issues. When you open up the cli for a router, the top third of the screen is not viewable
try this:
Go to Options > Preferences > Custom Interfaces
Set the 'Router' to 'clearTerminalAgent:terminal.html' in the dropdown box.
