Packets not getting encrypt and decrypt IPSEC
mahesh18
Level 6
Level 6
Hi Everyone,
I have 2691 Router conencted to Internet and it is doing Nat.
This connects to 3550A  Switch which has connection to 1811W  Router.
I setup VPN between 1811W and 3550A.
3550A has connection to 2691 via ospf.
OSPF is running between 1811w and 3550A.
1811
1811w# sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
192.168.99.2    192.168.99.1    QM_IDLE           2005 ACTIVE
IPv6 Crypto ISAKMP SA
1811w# sh crypto ipsec sa
interface: FastEthernet0
    Crypto map tag: VPN_MAP, local addr 192.168.99.1
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.0.0/255.255.0.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.99.0/255.255.255.0/0/0)
   current_peer 192.168.99.2 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 30, #recv errors 0
     local crypto endpt.: 192.168.99.1, remote crypto endpt.: 192.168.99.2
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet0
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
3550A
3550SMIA#        sh crypto isakmp sa
dst             src             state          conn-id slot status
192.168.99.2    192.168.99.1    QM_IDLE           1001 ACTIVE
3550SMIA#sh cry
3550SMIA#sh crypto ipsec sa
interface: FastEthernet0/8
    Crypto map tag: VPN_MAP, local addr 192.168.99.2
   current_peer 192.168.99.1 port 500
    #send errors 15, #recv errors 0
     local crypto endpt.: 192.168.99.2, remote crypto endpt.: 192.168.99.1
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
As seen above the packets are not encrypted between 1811w and 3550A.
I have used same ACL  on both 1811W and 3550A
ip access-list extended INTERESTING_TRAFFIC
permit ip 192.168.0.0 0.0.255.255 192.168.99.0 0.0.0.255 log
Any reasons why packets are not getting encrypt and decrypt?
MAhesh
2 Accepted Solutions
Reza Sharifi
Hi Mahesh,
Please post the full configs from both devices.
terminal length 0
than
sh run
Reza
Hi Mahesh,
I was just going through your configs.
I see pkts digst is incrementing now.
Glad is working now.
5 Replies 5
Reza Sharifi
Hi Mahesh,
terminal length 0
than
sh run
Reza
Hi Reza,
I have attached config from both devices to original post
Both are directly connected running ospf.
NAT is taking place on Router which is connected to 3550A
MAhesh
Hi REza,
Issue is fixed now.
Both devices had same ACL.
I changed ACL  on 3550A  now it is working fine
    #pkts encaps: 53, #pkts encrypt: 53, #pkts digest: 53
    #pkts decaps: 53, #pkts decrypt: 53, #pkts verify: 53
    #send errors 1, #recv errors 0
     current outbound spi: 0x8319FE5B(2199518811)
     inbound esp sas:
      spi: 0xAE0A578B(2919913355)
        transform: esp-des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 15, flow_id: Onboard VPN:15, sibling_flags 80000046, crypto map: VPN_MAP
        sa timing: remaining key lifetime (k/sec): (4454254/1764)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 16, flow_id: Onboard VPN:16, sibling_flags 80000046, crypto map: VPN_MAP
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
for all the help
MAhesh
Hi Mahesh,
Hi Reza,
Regards For always helping me
Mahesh
