PacketTracer 8 on macOS has problems with rpath.
ddm3rr1tt
installation go fine as a standard user and using the admin credentials.
executing packetTracer crashes, and appears to be an issue with rpath in the application.
executign as an elevated user (i.e admin) has no problems-but that is not the normal operation in a multiuser system and nor should it be don't in any system.
output of the crash follows:
Translated Report (Full Report Below)
Process:               PacketTracer [59696]
Path:                  /Applications/Cisco Packet Tracer 8.0.1/Cisco Packet Tracer 8.0.1.app/Contents/MacOS/PacketTracer
Identifier:            com.netacad.PacketTracer8.0.1
Version:               ???
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               504
Date/Time:             2021-09-29 09:16:02.8539 -0400
OS Version:            macOS 12.0 (21A5522h)
Report Version:        12
Anonymous UUID:        2F437DB7-6C55-8344-F800-1432C349D82A
Time Awake Since Boot: 150000 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace DYLD, Code 1 Library missing
Library not loaded: @rpath/libssl.1.1.dylib
Referenced from: /Applications/Cisco Packet Tracer 8.0.1/Cisco Packet Tracer 8.0.1.app/Contents/MacOS/PacketTracer
Reason: tried: '/Applications/Cisco Packet Tracer 8.0.1/Cisco Packet Tracer 8.0.1.app/Contents/MacOS/../Frameworks/libssl.1.1.dylib' (open() failed with errno=13), '/Applications/Cisco Packet Tracer 8.0.1/Cisco Packet Tracer 8.0.1.app/Contents/MacOS/../Frameworks/libssl.1.1.dylib' (open() failed with errno=13), '/usr/lib/libssl.1.1.dylib' (no such file)
(terminated at launch; ignore backtrace)
Application Specific Information:
Thread 0 Crashed:
0   dyld                                 0x10c4790ae __abort_with_payload + 10
1   dyld                                 0x10c48f1af abort_with_payload_wrapper_internal + 80
2   dyld                                 0x10c48f1e1 abort_with_payload + 9
3   dyld                                 0x10c43d7c3 dyld4::halt(char const*) + 375
4   dyld                                 0x10c4395e0 dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*) + 4127
5   dyld                                 0x10c4384b4 start + 388
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000002000209  rbx: 0x0000000000000000  rcx: 0x00007ff7b9202538  rdx: 0x00007ff7b92029a0
  rdi: 0x0000000000000006  rsi: 0x0000000000000001  rbp: 0x00007ff7b9202580  rsp: 0x00007ff7b9202538
   r8: 0x00007ff7b92025a0   r9: 0x0000000000000000  r10: 0x000000000000008e  r11: 0x0000000000000246
  r12: 0x000000000000008e  r13: 0x00007ff7b92029a0  r14: 0x0000000000000001  r15: 0x0000000000000006
  rip: 0x000000010c4790ae  rfl: 0x0000000000000246  cr2: 0x000000010c440000
Logical CPU:     0
Error Code:      0x02000209
Trap Number:     133
Binary Images:
       0x10c433000 -        0x10c49afff dyld (*) <9fc670fc-4d35-3582-a044-8f06bf2528af> /usr/lib/dyld
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=85.3M resident=0K(0%) swapped_out_or_unallocated=85.3M(100%)
Writable regions: Total=9444K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9444K(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
STACK GUARD                       56.0M        1
Stack                             8192K        1
VM_ALLOCATE                         12K        3
__DATA                            1944K        3
__DATA_CONST                        48K        1
__LINKEDIT                        12.7M        3
__TEXT                            72.6M        2
dyld private memory               1024K        1
shared memory                        8K        1
TOTAL                            152.2M       16
Full Report
{"app_name":"PacketTracer","timestamp":"2021-09-29 09:16:02.00 -0400","app_version":"","slice_uuid":"1f5564d9-a016-3c8d-8703-de73e108e3d7","build_version":"","platform":1,"bundleID":"com.netacad.PacketTracer8.0.1","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.0 (21A5522h)","incident_id":"3BA8E43C-538D-4585-9B5A-A9D47D3C1D42","name":"PacketTracer"}
  "uptime" : 150000,
  "procLaunch" : "2021-09-29 09:16:02.7981 -0400",
  "procRole" : "Default",
  "version" : 2,
  "userID" : 504,
  "deployVersion" : 210,
  "modelCode" : "MacPro6,1",
  "procStartAbsTime" : 156461846179870,
  "coalitionID" : 13407,
  "osVersion" : {
    "train" : "macOS 12.0",
    "build" : "21A5522h",
    "releaseType" : "User"
  "captureTime" : "2021-09-29 09:16:02.8539 -0400",
  "incident" : "3BA8E43C-538D-4585-9B5A-A9D47D3C1D42",
  "bug_type" : "309",
  "pid" : 59696,
  "procExitAbsTime" : 156461901499141,
  "cpuType" : "X86-64",
  "procName" : "PacketTracer",
  "procPath" : "\/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/PacketTracer",
  "bundleInfo" : {"CFBundleIdentifier":"com.netacad.PacketTracer8.0.1"},
  "storeInfo" : {"deviceIdentifierForVendor":"52B16674-AE5A-54C8-80C7-00C142FAB10B","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.netacad.PacketTracer8.0.1",
  "crashReporterKey" : "2F437DB7-6C55-8344-F800-1432C349D82A",
  "sip" : "enabled",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000000, 0x0000000000000000","rawCodes":[0,0],"type":"EXC_CRASH","signal":"SIGABRT"},
  "termination" : {"code":1,"flags":518,"namespace":"DYLD","indicator":"Library missing","details":["(terminated at launch; ignore backtrace)"],"reasons":["Library not loaded: @rpath\/libssl.1.1.dylib","Referenced from: \/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/PacketTracer","Reason: tried: '\/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/..\/Frameworks\/libssl.1.1.dylib' (open() failed with errno=13), '\/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/..\/Frameworks\/libssl.1.1.dylib' (open() failed with errno=13), '\/usr\/lib\/libssl.1.1.dylib' (no such file)"]},
  "asi" : {"dyld":["Library not loaded: @rpath\/libssl.1.1.dylib","Referenced from: \/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/PacketTracer","Reason: tried: '\/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/..\/Frameworks\/libssl.1.1.dylib' (open() failed with errno=13), '\/Applications\/Cisco Packet Tracer 8.0.1\/Cisco Packet Tracer 8.0.1.app\/Contents\/MacOS\/..\/Frameworks\/libssl.1.1.dylib' (open() failed with errno=13), '\/usr\/lib\/libssl.1.1.dylib' (no such file)"]},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":1672396,"threadState":{"r13":{"value":140701939542432},"rax":{"value":33554953},"rflags":{"value":582},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":1},"r8":{"value":140701939541408},"cr2":{"value":4500750336},"rdx":{"value":140701939542432},"r10":{"value":142},"r9":{"value":0},"r15":{"value":6},"rbx":{"value":0},"trap":{"value":133},"err":{"value":33554953},"r11":{"value":582},"rip":{"value":4500983982,"matchesCrashFrame":1},"rbp":{"value":140701939541376},"rsp":{"value":140701939541304},"r12":{"value":142},"rcx":{"value":140701939541304},"flavor":"x86_THREAD_STATE","rdi":{"value":6}},"frames":[{"imageOffset":286894,"symbol":"__abort_with_payload","symbolLocation":10,"imageIndex":0},{"imageOffset":377263,"symbol":"abort_with_payload_wrapper_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":377313,"symbol":"abort_with_payload","symbolLocation":9,"imageIndex":0},{"imageOffset":42947,"symbol":"dyld4::halt(char const*)","symbolLocation":375,"imageIndex":0},{"imageOffset":26080,"symbol":"dyld4::prepare(dyld4::APIs&, dyld3::MachOAnalyzer const*)","symbolLocation":4127,"imageIndex":0},{"imageOffset":21684,"symbol":"start","symbolLocation":388,"imageIndex":0}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4500697088,
    "size" : 425984,
    "uuid" : "9fc670fc-4d35-3582-a044-8f06bf2528af",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
  "sharedCache" : {
  "base" : 140703317172224,
  "size" : 15210168320,
  "uuid" : "86f94346-1656-3799-948e-81599fc44640"
  "vmSummary" : "ReadOnly portion of Libraries: Total=85.3M resident=0K(0%) swapped_out_or_unallocated=85.3M(100%)\nWritable regions: Total=9444K written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=9444K(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nSTACK GUARD                       56.0M        1 \nStack                             8192K        1 \nVM_ALLOCATE                         12K        3 \n__DATA                            1944K        3 \n__DATA_CONST                        48K        1 \n__LINKEDIT                        12.7M        3 \n__TEXT                            72.6M        2 \ndyld private memory               1024K        1 \nshared memory                        8K        1 \n===========                     =======  ======= \nTOTAL                            152.2M       16 \n",
  "legacyInfo" : {
  "threadTriggered" : {
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "607844aa04477260f58a8077",
      "factorPackIds" : {
        "SIRI_MORPHUN_ASSETS" : "60ef663fa2f864203caf575c"
      "deploymentId" : 250000055
      "rolloutId" : "60356660bbe37970735c5624",
      "factorPackIds" : {
      "deploymentId" : 250000016
      "rolloutId" : "60da5e84ab0ca017dace9abf",
      "factorPackIds" : {
      "deploymentId" : 250000007
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 250000124
      "rolloutId" : "5ffde50ce2aacd000d47a95f",
      "factorPackIds" : {
      "deploymentId" : 250000036
      "rolloutId" : "602ad4dac86151000cf27e46",
      "factorPackIds" : {
        "SIRI_DICTATION_ASSETS" : "61522de741685658846fadce"
      "deploymentId" : 250000205
      "rolloutId" : "601d9415f79519000ccd4b69",
      "factorPackIds" : {
        "SIRI_TEXT_TO_SPEECH" : "61522cf341685658846fadb6"
      "deploymentId" : 250000224
  "experiments" : [
Model: MacPro6,1, BootROM 428.140.7.0.0, 6 processors, 6-Core Intel Xeon E5, 3.5 GHz, 64 GB, SMC 2.20f18
Graphics: AMD FirePro D500, AMD FirePro D500, PCIe, 3 GB
Display: ASUS PB287Q, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Display: ASUS PB287Q, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), MirrorOff, Online
Memory Module: DIMM1, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM2, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM3, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
Memory Module: DIMM4, 16 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343247523742465234432D52442020
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1710.1)
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: AMD FirePro D500, Display Controller, Slot-1
PCI Card: AMD FirePro D500, Display Controller, Slot-2
Serial ATA Device: APPLE SSD SM1024G, 1 TB
USB Device: USB30Bus
USB Device: ATAPI-6 Bridge Controller
USB Device: DT microDuo 3C
USB Device: USB2.0 Hub
USB Device: 2Port KVMSwitcher
USB Device: Keyboard Hub
USB Device: Apple Optical USB Mouse
USB Device: Apple Keyboard
USB Device: USB20Bus
USB Device: hub_device
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
ddm3rr1tt
OK...found the solution.
unlink most, I have 2 accounts -- 1 for administrative user and 1 for standard user.
I use the standard user account for all normal activity.
the rpath problem isn't that it can't find the file, but more so, access/execute it.
the permissions are incorrect on the libssl.1.1.dylib in the relative Frameworks directory.
they should be rwxr-xr-x rather than rwx--x--x to allow the files to be read in order to be executed.
I think Apple switched from OpenSSL to LibreSSL, that might be where this error comes from...
ddm3rr1tt
unlikely...plus as stated, it works fine if i run it with elevated privileges such as administrator or root.
ddm3rr1tt
Hi @ddm3rr1tt !
i have the same setup as you have in terms of admin/user on catalina. installation went fine, but PT just wont start at all (my first guess aswell was that it maybe some permission issue, but i havent figured out how to run PT up to now (well i havent tried up to now really, only looking it up at first to see if someone already had an issue with it before doing enything. i also was surprised  that with PT  it auto installed Linguist additionally, but it seems to be necessary for the GUI i guess
