PAGP rate FAST
loudo
Hi all,
We have seen in 12.2.18SXF12 (maybe also available in earlier releases) that the following interface configuration command in available:
MPLS_RTR13_SUP720(config-if)#pagp rate ?
fast PAgP packets are transmitted at the fast rate
This command seems to work as the "lacp rate fast" but the difference is that this pagp command is not referenced on the CCO neither in the command reference guides.
Could anyone confirm me that this command is supported or not?
Our customer infrastructure is in pagp and we would prefer to keep this protocol and use the rate fast feature than modifying all etherchannel from pagp to lacp to get advantage of the rate fast feature.
Many thanks.
Regards/ludovic.
mchin345
Level 6
Level 6
Could you post your show tech output.
Why would you need a sh tech to confirm if this command is supported by CISCO in 12.2.18SXF12 or not?
Regards/Ludovic.
