passthough traffic on router interface
dbakula01
this is a 1721 router terminiating a t1. what i am looking for is not having to use an ip on the fe0 interface. is there any way to do this without assigning an ip to the inside address and just passing traffic through the interface from behind it? also are there any security implications behind this?
interface FastEthernet0
no ip address
speed auto
interface Serial0
ip address xxxxxxxxx 255.255.255.240
no fair-queue
ip classless
ip route 0.0.0.0 0.0.0.0 xxxxxxxx
Richard Burts
Darren
I am not clear what you are trying to accomplish but I do not think that you want to do it this way. If you configure FastEthernet0 with no ip address, then the router will not send IP traffic over that interface.
If you are trying to conserve address space I have seen routers in situations similar to this which configure serial0 with ip unnumbered fastethernet0, and put the IP address on the FastEthernet. This does require some coordination with the router on the other end of the T1.
If that is not the solution that you are looking for, then perhaps you can clarify your environment and what you are trying to accomplish.
Rick
Rick
