Password Issue Catalyst 2960-s PoE
sohani3653
I am trying to recover the password of Catalyst 2960-s PoE ( WS-C2960S-24PS-L 12.2(55)SE3 C2960S-UNIVERSALK9-M) but no options are working like by pressing Mode button and by giving the under mentioned commands
switch: flash_init
switch: load_helper
switch: dir flash:
When these commands are given it shows;Translating "flash_init"...domain server (255.255.255.255)
Can someone help Please?
Seb Rupik
Hi there,
those are ROMMON commands. You need to disconnect the power, hold the mode button then reattach the power cable:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swtrbl.html
Step 6 Press the Mode button and at the same time, reconnect the power cord to the switch.
You can release the Mode button a second or two after the LED above port 1 goes off. Several lines of information about the software appear along with instructions:
The system has been interrupted prior to initializing the flash file system. The following commands will initialize the flash file system, and finish loading the operating system software#
cheers,
Seb.
Giuseppe Larosa
Hello @sohani3653 ,
it is not enough to press the mode button to go to ROMMON you need to power cycle the switch when the switch is powered on you press the mode button for 5-10 seconds this is the way to go to ROMMON
the message
this message is an error message of IOS and this means you are not in ROMMON
Hope to help
Giuseppe
