Password Recovery for 4507 with Two supervisor
Hi. I have catalys 4507 with TWO supervisor V
I flowed this procedur :
http://www.cisco.com/en/US/products/hw/switches/ps663/products_password_recovery09186a00800945f7.shtml
after the reset normaly i can change the password and i check the confreg is 0X2142 but it still ask to enter the possword
should i remove 1 supervisor and do the procedure or i must let the two spuervisor ?
thanks in advance for your help
Reza Sharifi
Hi Youssef,
Are you trying to recover the primary sup or the backup?
i try to recover the password for the Two supervisor ,
i try the procedure with the two supervisor pluged on , but i failed to change the password.
so is this procedure function with the two supervisor online or should i try  with one supervisor online at once ?
or is their any other procedure to folow when ther is two supervor active
