01-14-2012 08:09 AM - edited 03-07-2019 04:21 AM
HI
i have configured cisco 6509 to do pating and its not working.Static nat is perfectly working fine below is the config
int vlan 70
ip nat inside
int vlan 179
ip nat outside
ip nat inside source list 10 pool nat_pool overloaded
ip nat nat pool nat_pool 1.1.1.1 1.1.1.1 netmask 255.255.255.0
ip access-list standard 10
permit 10.10.10.0 0.0.0.255
kindly advice
01-14-2012 08:24 AM
kindly advice
Are you sure your syntax is really as above?
PAT works best when specifying an interface instead of a pool. Please try to use:
ip nat inside source list 10 interface vlan 179 overload as in:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009448f.shtml
regards,
Leo
01-14-2012 09:10 AM
Hi Leo,
just a quick note to say that when specifying the interface in NAT overload the overload keyword is automatically added by the IOS in the configuration so there's no need to specify it.
Regards.
Alain
01-14-2012 09:17 AM
Yes, I know that but I was triggered by overloaded instead of overload and ip nat nat pool nat_pool where, IMHO, there is a keyword too many. This output was not gathered from the CLI, probably just quickly typed without checking.
Pleae draw your own conclusions.
Leo
01-14-2012 10:19 AM
Hi Leo,
No harm intended this was just a remark for the OP but as you had proposed the statement that's why I answered you.
I draw no conclusions different from you.
Regards.
Alain
01-14-2012 09:20 PM
Thanks to all for replying and sorry about spelling mistake as it was typed in urgency.
I use interface also but not working.It may be a bug on IOS
01-15-2012 12:04 AM
Perhaps if you can share the output of sh ver and sh module with us, we can say anything about that.
regards,
Leo
