PBR and Routing
Jacob Samuel
I just want to know about some facts of PBR.
When i configure PBR, will it take place before the normal route process works?
In case if the link failed what will happend to the packet?
Thanks & Regards
Sunny
Ok, then
ip sla 1
icmp-echo 192.168.1.2
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
track 10 rtr 1 reachability
delay down 1 up 1
ip route 0.0.0.0 0.0.0.0 172.16.1.2
route-map PBR permit 10
match ip address 10
set ip next-hop verify-availability 192.168.1.2 1 track 10
int f0/0
ip add 192.168.1.1 255.255.255.0
ip policy route-map PBR
here is useful link
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtpbrtrk.html
And example with good explanation
https://supportforums.cisco.com/docs/DOC-8313
hope it will help.
Best regards,
Abzal
6 Replies 6
Abzal
Level 7
Level 7
1. Yes, when PBR applied on interface all incoming packets goes through match criteria on route-maps. If match found with permit statement packets will be forwarded next-hop defined in PBR. If there is match with deny clause or match does not found then packets goes through normal destination based forwarding table.
2. Packets will be dropped. That's why there is a option like set ip next-hop verify reachability to track interface.
Hope it will help.
Best regards,
Abzal
Thanks a lot, how to configure this, can i get any sample config  for this.
Tahnks & regards
Sunny
Here is a simple config:
access-list 10 permit 192.168.1.0 0.0.0.255
Route-map pbr permit 10
match ip address 10
set ip next-hop 10.0.0.1
int f0/0
ip policy route-map pbr
Best regards,
Abzal
thanks, but where to add the command set ip next-hop verify reachability
regards
Jacob
Ok, then
ip sla 1
timeout 500
frequency 1
delay down 1 up 1
match ip address 10
int f0/0
here is useful link
hope it will help.
Best regards,
Abzal
