PBR criteria
Adrian Ardelean
I need to make a route-map to set the ip next-hop if the destination IP in NOT in 172.16.0.0/16 network.
Is it possible?
Thank you!
access-list 100 deny any 172.16.0.0 0.0.255.255
access-list 100 permit ip any any
route-map PBR
match ip add 100
set ip next-hop x.x.x.x
int x/x
ip policy route-map PBR
Regards.
Alain
vaib7av.shirkul
Hi ,
For configuring PBR, IP address in ip-next-hop command must be directly connected and in same network.
for more details u can refer below link,
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html
HTH,
Yes, it is directly connected and in same network. I just don't know the "NOT expression"
Thank you!
route-map PBR
match ip add 100
int x/x
Regards.
Alain
Thanks a LOT!!
It's VERY working!
