PBR issues on SVIs with Catalyst 9300
I would like to know what are the commands available on Catalyst 9300 IOS-XE devices for checking packet drops in the forwarding path. I am seeing an issue where PBR route-map and ACL is showing hit counts - but packet is getting dropped. I checked all basic things like SVI Configs, PBR NextHop's ARP entry etc. Packet comes in on a SVI and gets PBR'ed onto another SVI. Egress link is a L2 port-channel in the Egress SVI.
5 Replies 5
Reza Sharifi
Do you see any packet drops on the ingress or egress physical interfaces?
"sh interface x/x" should show you input and/or output drops.
No drops in show interface ....
So, where do you see packet drops?
I am exactly trying to figure out that :-)
Please let me know what commands can be used to figure out Forwarding drops in the ASIC. show interfaces - does not give the forwarding drops.
Sorry my bad - I forgot the fundamental command "ip routing". Consider this closed.
