PBR loop
omoplatata
Community Member
I'm writing a config that requires me to forward all network traffic comming to a router interface back to it's source, thus creating a small loop. For instance the configuration would look like this:
ip route 10.0.0.1 255.255.255.255 FastEthernet 0/0
ip access list extended LIST
   permit ip host 10.0.0.1 any
route-map MAP permit 10
   match ip address LIST
   set ip next-hop 10.0.0.1
interface FastEthernet 0/0
   ip address 10.1.0.1 255.255.255.252
   ip policy route-map MAP
I try to test it by sending packets from 10.0.0.1 having 10.1.0.1 as it's destination address. My problem is that while I can verify that I recive inound traffic on the interface and I see policy routing matches, I don't see any outbound traffic on FastEthernet 0/0. I really can't figure it out, I've tried many PBR config variation but still no dice. Any help would be much appreciated.
blau grana
Level 11
Level 11
Hello omoplatata,
Configuration looks OK, it should work. Check if your static route is in routing table, if routing table contain some specific route for 10.0.0.1/32, PBR traffic will be routed based on rules of routing table.
Also I would change this static route:
to this:
ip route 10.0.0.1 255.255.255.255 10.1.0.2
You can have ARP issues with previous format, check ->
http://blog.ioshints.info/2009/10/my-stupid-moments-interface-default.html
http://blog.ioshints.info/2009/10/follow-up-interface-default-route.html
To check outbound traffic, you can configure ACL:
From 10.0.0.1 device ping some IP, f.e. 8.8.8.8
On router add this ACL:
ip access-list extended TEST
permit icmp host 10.0.0.1 host 8.8.8.8
permit ip any any
interface FastEthernet0/0
ip access-group TEST out
But if you have access to 10.0.0.1 device, you should be able to see looped traffic there.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
