PBR on Catalyst 3650
moto.kne
Hello!
I would like to know how to verify PBR running on Catalyst 3650 switch is working. (The version is 16.6.4)
I tried some commands below but they didn't clarify whether or not it was operating properly.
 - show ip access-list
      * The match counter was not incremented.
 - show route-map
 - debug ip policy
      * No output was displayed.
Because Catalyst 3650 processes PBR on the hardware, do these commands not show anything?
Thank you in advance.
Best Regards,
post the config of your 3650....
Seeing the config will be very helpful. In particular we will be looking to see if the route map for PBR is applied on the interface where the traffic arrives at the switch.
Rick
Rick
