PC2 Host Not Reachable
eschubauer
I have been working with GNS3 a lot over the last 6 months and have been learning so much. I setup a simple network the other day and suddenly PC2 doesn't ping to my default-gateway. It states "host (192.168.1.1) not reachable. PC1 pings fine. My setup is a Router - Switch - PC1 and PC2
I never had this problem before and it makes me thing it's a GNS3 problem suddenly.
R1(config): int f0/0
R1(config-if): no shut
R1(config-if): ip address 192.168.1.1 255.255.255.0
ESW1(config): int vlan 1
ESW1(config-if): no shut
ESW1(config-if): ip address 192.168.1.2 255.255.255.0
ESW1(config-if): ip default-gateway 192.168.1.1
VPCS1: ip 192.168.1.3 255.255.255.0 192.168.1.1
(This PC pings fine)
VPCS2: ip 192.168.1.4 255.255.255.0 192.168.1.1
(This is where the problem begins and on any other PC I add suddenly. Never had this problem before)
I've attached my GNS3 file as well in zip form.
5 Replies 5
Mark Malone
devices in the same subnet arp to eachother and don't require routing so if your arp is  complete for both pcs ips and the macs are complete then the issue is with the software , its an emulator and they can be quite buggy , your config looks correct and the fact pc1 works proves it as there identical setup
Austin Sabio
Level 4
Level 4
Please use the supported generic switch in GNS3 (has no console and can be configured via GUI). I think it's related to the unsupported VM switch.
si, es asi !! el sw no esta soportado ., tenia el mimsmo problema y cambiando el sw se soluciono
azibnaseem
Hey [@eschubauer@mjpeterson.com]  '
I have configured a mirrored topology & configuration into GNS3 & I can successfully ping from both PC's to Router (192.168.1.1) IP Address.
Ping & Configuration screen shots are attached for your review.
Moreover please share the output of command show ip int br form the switch & router.
Regards'
eschubauer
Thank you everybody for your input. I use an ethernet switch and for some reason need to make sure the speeds and duplexes are exact. After correcting that I was able to ping again.
