Periodic reauthentication for rejected 802.1x Clients
StefanUlrich
Is there a possibility to enable a periodic reauthentication of rejected 802.1x/MAB Clients?
When I configure authentication timer reauthenticate <time> or authentication timer reauthenticate server on an interface I see the Session Timeout only for permitted clients:  Session timeout: 3600s (server), Remaining: 3587s  or Session timeout: 120s (local), Remaining: 99s. When the Client is rejected by ISE I see always: Session timeout: N/A no matter if I configure a local timer or I add a reauth-timer to the DenyAccess on ISE.
Background: Whe had a problem with ISE which rejected Clients due to a licensing problem and all these clients had to be reauthenticated later. So I was asked if it would be possible to reauthenticate rejected clients on the Switch.
pieterh
do you also have the command "authentication periodic" in addition to the authentication timer in your config?
Yes, it's included.
