Ping between Switch, no Switch - Router
sinergycena
Im doing ping from Switch 1 to Switch 2 using 172.20.34.90 and is ok, but when i want to do ping between Switch1 and Router 1 using 172.20.34.91 i can't
Success rate is 0 percent (0/5)
¿someone could help me with this?
SW1
en
conf t
hostname SW1
vlan 10
name l10
vlan 20
name l20
vlan 30
name l30
vlan 40
name l40
Vlan 201
name Admin
Vlan 110
name Nativa
interface fastEthernet0/1
switchport mode access
switchport access vlan 10
no shutdown
interface fastEthernet0/2
no shutdown
interface fastEthernet0/7
switchport access vlan 20
no shutdown
interface fastEthernet0/8
no shutdown
interface fastEthernet0/13
switchport access vlan 30
no shutdown
interface fastEthernet0/19
switchport access vlan 40
no shutdown
interface fastEthernet0/10
switchport mode trunk
switchport trunk allowed vlan 10,20,30,40,110,201
switchport trunk native vlan 110
switchport trunk allowed vlan except 1
no shutdown
interface vlan 201
ip address 172.20.34.89 255.255.255.248
ip default-gateway 172.20.34.91
end
write
SW2
en
conf t
hostname SW2
vlan 10
name l10
vlan 20
name l20
vlan 30
name l30
vlan 40
name l40
Vlan 201
name Admin
Vlan 110
name Nativa
no shutdown
no shutdown
no shutdown
no shutdown
no shutdown
interface fastEthernet0/14
no shutdown
no shutdown
interface fastEthernet0/20
no shutdown
ip address 172.20.34.90 255.255.255.248
no shutdown
interface fastEthernet0/24
no shutdown
interface vlan 201
no shutdown
end
write
R1
en
conf t
hostname R1
interface f0/0.10
encapsulation dot1q 10
ip address 172.20.0.1 255.255.255.0
interface f0/0.20
encapsulation dot1q 20
ip address 172.20.1.1 255.255.255.128
interface f0/0.30
encapsulation dot1q 30
ip address 172.20.1.129 255.255.255.224
interface f0/0.40
encapsulation dot1q 40
ip address 172.20.4.1 255.255.252.0
interface f0/0
ip address 172.20.34.91 255.255.255.248
no shutdown
interface f0/1
ip address 172.20.34.65 255.255.255.252
no shutdown
ip dhcp excluded-address 172.20.0.1 172.20.0.10
ip dhcp excluded-address 172.20.1.1 172.20.1.10
ip dhcp excluded-address 172.20.1.129 172.20.1.139
ip dhcp excluded-address 172.20.4.1 172.20.4.10
ip dhcp pool VLAN10
network 172.20.0.0 255.255.255.0
default-router 172.20.0.1
dns-server 172.20.34.116
ip dhcp pool VLAN20
network 172.20.1.0 255.255.255.128
default-router 172.20.1.1
ip dhcp pool VLAN30
network 172.20.1.128 255.255.255.224
default-router 172.20.1.129
ip dhcp pool VLAN40
network 172.20.4.0 255.255.252.0
default-router 172.20.4.1
router eigrp 100
network 172.20.34.64 255.255.255.252
network 172.20.34.88 255.255.255.248
eigrp router-id 1.0.0.0
end
write
add native to Router's interface FastEthernet0/0.201 dot1Q 201 interface, aka
encapsulation dot1Q 201 native
ever time you modify 802.1q native vlan id , you must match on the other side; i assume router thought vlan 1 is still native vlan, thats it did not work.   Note: on sw2 you had changed native vlan to be 201
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
Giuseppe Larosa
Hello @sinergycena ,
I have correcty understood your topology you have:
SW1 ----  SW2 ----- R1
the connectivity should happen in VLAN 201 .
On R1 you have configures some Vlan based subinterfaces under fas0/0, but the subnet of Vlan 201 is under fas0/0 with no subinterface this is not correct.,
with your current configuration you need
R1
int fas0/0.201
enc dot1q 201
desc
no shut
as an alternative you can change the native vlan to 201 on the swich port to R1:fasa0/0 on SW2.
This why at the moment you cannot ping R1
It's not working , as you can see, I can do it between switch, but, when I want to ping to router, i can't
NsfQLb6
Let me show you more. After the change with you'r advice
This R1
2MeZZhgRunning Config R1
hostname R1
ip dhcp pool VLAN10
ip dhcp pool VLAN20
ip dhcp pool VLAN30
ip dhcp pool VLAN40
no ip cef
no ipv6 cef
spanning-tree mode pvst
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
interface FastEthernet0/0.30
 encapsulation dot1Q 30
interface FastEthernet0/0.40
 encapsulation dot1Q 40
interface FastEthernet0/1
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 100
 network 172.20.0.0 0.0.0.255
 network 172.20.1.0 0.0.0.127
 network 172.20.1.128 0.0.0.31
 network 172.20.4.0 0.0.3.255
 network 172.20.34.64 0.0.0.3
 network 172.20.34.88 0.0.0.7
 auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
Running Config SW1
hostname SW1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
 switchport trunk allowed vlan 2-1005
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan201
 mac-address 00d0.9722.3401
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Running Config SW2
hostname SW2
switchport trunk native vlan 201
interface Vlan1
no ip address
shutdown
interface Vlan201
mac-address 0060.2fe1.1701
line con 0
line vty 0 4
login
line vty 5 15
login
end
Martin L
You can attach PT file here; it just have to be in format of a zip file. so, zip it and attach to post. it will be faster to see issue.
Regards, ML
Well, is bigger, in Cluster
Router 1 / Switch 1,2 / Vlan 10,20,30,40
Regards, ML
Or ... what is alternative solution without touching router ?
Thanks, Thanks! now I can to send a backup to my server in Admin4 vlan 172.20.34.116
However, if there is a alternative to do it, I want to know it
Thanks @Giuseppe Larosa for help me too
Or remove native vlan 201 on Sw - on interface that is trunking towards router
no switchport trunk native vlan 201
