ping fail from edge switch
suthomas1
Level 6
Level 6
Devices connected in vlan 99(Static Ip) are unable to be reached via icmp from pc's connected in vlan 200.
I suspect arp inspection to be culprit here. appreciate if people can help out.
interface Vlan 99
ip address 192.168.99.1 255.255.255.0
ip verify unicast source reachable-via rx
no ip redirects
no ip unreachables
no ip proxy-arp
ip wccp 11 redirect out
ip pim sparse-mode
port configuration for device in vlan 99 on edge switch ;
( the device is connected to port with static ip 192.168.99.32 )
interface FastEthernet1/0/11
  switchport access vlan 99
switchport mode access
switchport port-security maximum 3
switchport port-security aging time 5
switchport port-security violation restrict
storm-control broadcast level 20.00 10.00
storm-control multicast level 20.00 10.00
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable19
spanning-tree guard root
ip dhcp snooping limit rate 15
i see following in the layer3 switch;
ip arp inspection vlan 10,92-103
ip arp inspection validate src-mac
ip dhcp snooping vlan 1-724
Portchannel on layer 3 which connects the edge switch  has this configuration;
interface Port-channel5
switchport
switchport mode trunk
ip arp inspection limit none
no ip address
mls qos trust cos
storm-control broadcast level 5.00
storm-control multicast level 5.00
similar configuration on the edge switch is;
ip arp inspection trust
ip dhcp snooping trust
[EDIT - I guess there can be a static binding put in for this to work , but that will be cumbersome with many static ip's for such devices in the network.]
Please help.
thanks in advance!
Message was edited by: sunny thomas
suthomas1
Level 6
Level 6
will it help if the vlan is removed from inspection list?
