ping issue on 1721
delacoadmin
Good afternoon all. I have a ping issue regarding a pc and a 1721 router fa0 connected to a 2512 switch. PC will ping fa0, however, fa0 cannot ping the PC. Bypassed the switch and got the same results. Any ideas?
Current configuration : 810 bytes
version 12.4
service tcp-keepalives-out
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
no ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface Ethernet0
no ip address
shutdown
half-duplex
interface FastEthernet0
ip address 192.168.3.1 255.255.255.0
speed auto
no arp arpa
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
ip address 10.2.2.1 255.255.255.252
clock rate 64000
no ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
R3#
Jon Marshall
If the PC can ping the router but not the other way round check your PC to see if it has a firewall enabled that is blocking incoming ICMP echo requests.
Jon
Jon Marshall
Jon
delacoadmin
Thanx, just installed new IOS and Cisco WIC-2A/S WIC-2AS 2-PORT ASYNC/SYNC SERIAL module, didn't think of the obvious. Any help on why S1 would not be able to ping itself?
William
Based on what we see in the config there might be several reasons why the serial 1 can not ping itself:
- is the interface up? if you do show ip interface brief, does the serial 1 show as up/up? If the interface is not up then it can not ping itself.
- is something connected on the other end of the serial link? On point to point serial interfaces the ping must actually go out the interface, go to the device on the other end, and come back. So if there is no device on the other end the ping will fail.
- is the device on the other end configured with the same protocol (HDLC, PPP, etc)? If the devices are not configured with the same protocol then they can not communicate and the ping will fail.
- is the device on the other end configured with an IP address in the same subnet as your interface. As mentioned before on point to point serial interfaces the ping must go out the interface, get to the other device, which must forward it back on the serial link to you. If the other device is not configured with an IP address in the same subnet then the ping will fail.
Rick
Rick
wenfeizhang
maybe because you use the command "no arp arpa "
