Hi all,
Below is my current setup ->
![1 1](/legacyfs/online/media/wat.png)
All required routes are setup and R1 fe0/0 (3.1) and R10 fe0/0 (5.2) can both ping to 1 another.
While playing around, I done a wireshark capture on R2 Fe0/1(5.1) & then ping from R10 to 192.168.3.0 -- my reason for doing this is just to see if network ID is pingable or not -- and its pingable
R10#ping 192.168.3.0
Sending 5, 100-byte ICMP Echos to 192.168.3.0, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/46/64 ms
On R2 Fe0/1 capture, I saw this
4 5.312803000 192.168.5.2 192.168.3.0 ICMP 114 Echo (ping) request id=0x0004, seq=0/0, ttl=255 (no response found!)
5 5.359680000 192.168.5.1 192.168.5.2 ICMP 114 Echo (ping) reply id=0x0004, seq=0/0, ttl=255
6 5.406557000 192.168.5.2 192.168.3.0 ICMP 114 Echo (ping) request id=0x0004, seq=1/256, ttl=255 (no response found!)
7 5.422183000 192.168.5.1 192.168.5.2 ICMP 114 Echo (ping) reply id=0x0004, seq=1/256, ttl=255
However, on R1 Fe0/0 capture, I did not even receive anything.
q1) Is a network ID pingable ? if yes, who will reply to the ping ?
q2) what does the capture above - "no response found" meant ? from R10 (fe0/0) ? How does it know that there is no response found even before there is a reply coming back to to it ?
q3) why is R2 Fe0/1 (5.1) replying on behalf ?
q4) why isnt any packet send from R2Fe0/0 to R1Fe0/0 ?
Noob
