ping PPPoE local virtual-access interface
With following config R2 acts as PPPoE server (R2 assign an IP address to a PPPoE client via DHCP)
ip dhcp excluded-address 10.10.1.2 10.10.1.254
ip dhcp pool R1
   network 10.10.1.0 255.255.255.0
bba-group pppoe global
virtual-template 2
interface FastEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
interface Virtual-Template2
ip address 10.10.1.2 255.255.255.0
no peer default ip address
On R2 when PPP session go up a virtual-access interface is cloned form virtual-template:
R2#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/1            10.10.2.2       YES NVRAM  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access1.1          10.10.1.2       YES TFTP   up                    up <---------
Virtual-Access2            unassigned      YES unset  down                  down
Virtual-Template2          10.10.1.2       YES NVRAM  down                  down
Now I can ping the remote side (PPPoE client) but not the local interface (10.10.1.2)
R2#deb ip pack det
IP packet debugging is on (detailed)
R2#
R2#
R2#ping 10.10.1.2 re 2
Sending 2, 100-byte ICMP Echos to 10.10.1.2, timeout is 2 seconds:
*Mar  1 00:05:36.531: IP: tableid=0, s=10.10.1.2 (local), d=10.10.1.2 (Virtual-Access1.1), routed via RIB
*Mar  1 00:05:36.535: IP: s=10.10.1.2 (local), d=10.10.1.2 (Virtual-Access1.1), len 100, sending
*Mar  1 00:05:36.539:     ICMP type=8, code=0
*Mar  1 00:05:38.531: IP: tableid=0, s=10.10.1.2 (local), d=10.10.1.2 (Virtual-Access1.1), routed via RIB
*Mar  1 00:05:38.535: IP: s=10.10.1.2 (local), d=10.10.1.2 (Virtual-Access1.1), len 100, sending
*Mar  1 00:05:38.539:     ICMP type=8, code=0
Success rate is 0 percent (0/2)
R2#
from debug it seems R2 originates ICMP echo, route the packet to virtual-access1.1 and then this (sw) interface send it...
I've checked on the remote side....ICMP echoes are not received (as instead when pinging the local IP address configured on a serial interface...)
Why this behaviour ? Thanks.
Any idea ? Thanks.
looks like the virtual-template interface is not pingable.
what you can do is to have a loopback interface with the IP you want to assign to virtual-template and then under virtual-template do an unnumbered ip address:
interface Loopback1
 ip address 192.168.2.1 255.255.255.0
interface Virtual-Template1
 mtu 1492
 ip unnumbered Loopback1
 peer default ip address pool pool-1
this way you can ping both local and peer IP:
R1#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/24/32 ms
R1#ping 192.168.2.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
another way would be to use ppp multilink, but I could only make it work if you have virtual-template interfaces on both ends (like you'd use for ppp over frame-relay)
