Ping works, traceroute/ssh doesn't
HQuest
Hello. Thanks in advance for read this.
It must be something very basic but somehow I can't see it. I have a couple routers connected as follows (simplified layout as there are way more routers on the FR cloud):
[Internet] <-- ATM --> [Router_A] <-- Ethernet --> [Router_B] <-- Frame Relay --> [Router_C]
On Router_A I have:
  • Vlan100 as 192.168.0.1
  • Vlan200 as 192.168.2.1
  • Gi0/0 as switchport access vlan100, no IP address
  • Gi0/1 as switchport access vlan200, no IP address
On Router_B I have:
  • Gi0/0 as 192.168.2.2
  • S0/0/0 as 192.168.255.1
On Router_C I have:
  • S0/0/0 as 192.168.255.10
  • Gi0/0 as 192.168.10.1
The ACLs on router A are very basic:
Int ATM0
ip nat outside
Int Vlan100
ip nat inside
Int Vlan 200
ip nat inside
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 192.168.255.0 0.0.0.255 any
access-list 100 deny ip any any
ip nat inside source list 100 interface ATM0 overload
There are no ACLs on routers B and C.
All network routes are visible on the routers via multiple OSPF areas. Also, routers B and C use A as NTP server, and yes, clocks can sync!
- Both B and C can ping and traceroute any Internet address.
- Both B and C can talk to a netflow collector machine on Vlan100.
- Router A can SSH to B, but cannot to C.
- Router B can SSH to A.
- Router C cannot SSH to A.
- Both B and C can ping A, but none ca traceroute to A.
I tried to mirror the Vlan100 and Vlan200 traffic on router A using the "ip traffic-export" command. On the Wireshark machine all I could see were the ICMP echo request/reply packets and the traceroute UDP packets being sent, but no responses were being sent from my Vlan100 address on router A back to either B or C.
What am I missing?
HQuest
... looks like I found what was wrong, and it was indeed something very, very basic.
On Router_A:
int Vlan100
no ip unreachables
int Vlan200
no ip unreachables
That broke traceroute. Regarding SSH, it looks like the source routers I was using were running older IOS and their clients don't support SSH v2. I redid those tests from other routers running newer IOS code and it was all flawless.
I am glad that you were able to solve your own problem. And the issues that you found would certainly cause the symptoms that you describe. Thank you for posting back to the forum telling us what you found and how you fixed the problems. It can be very helpful to other readers when we have this kind of information.
Rick
Rick
Jeff Van Houten
Level 5
Level 5
On router b gi0/0 do you have encapsulation dot1q 200?
