Plase advice me for InterVlan to access Internet C3560
sweetpigy
Plase advice me for InterVlan to access Internet from Router 2811 and Switch 2960
, Now on both switch cann't access internet Please Me to revise my configuration.
* I used nat overload on router, Before i create vlan i user vlan 1 only it still work it can access internet , but after i create vlan on both switch it cann't access.
Thank you su much.
JORGE RODRIGUEZ
Level 10
Level 10
can you provide config for 2821 router shown in diagram.
Jorge Rodriguez
CiscogeekIND
Configure HSRP on both the switches. It will work.
sweetpigy
i don't use HSRP on both switch.Config of C3560 i can't access in it because it from ISP.
but when i bring computer connect fa0/0 (now it connect to switch 3560) it's work, i can access internet.
please advice for me.
Can you clarify some things:
What about VTP, is it configured in ISP switch?
What is the gateway for the system connected to your switch (From where You are not able to access internet).
